Case 504 Rods
JDGnut
I'm looking for the specs on a Case 504 Rod.
What I'm really looking for is a rod that has a 2.75 In Rod journal, and if I remember correctly the 504 Case did?
Is there a good place online to go for those type of Detailed specs.
Thanks,
Bryan
A lot of Case engines used a 2.75 rod journal only some of the 504s did. What exact info you need pin size and length?
Thanks guys... I'm not worried about the piston pin end.. Need a rod that has a wide bearing that is 2.75 diameter Journal..
So the small journalled 504 Case engine..
What else...
(quoted from post at 17:57:10 03/26/15) Thanks guys... I'm not worried about the piston pin end.. Need a rod that has a wide bearing that is 2.75 diameter Journal..
What else...
Any connecting rod from the big 400 600 700 800 900 730 830 930 1030, 70 series through the 1270 then transition to the 3" rod on the high HP engines 1370 and up, 20, 2290 are small crank 23 25 large crank. Small crank engines all have 10.5" CL rods and the large are 10" CL rods. Wrist pin sizes vary with the older being the smallest and later had larger pins.
