John Saeli
Sounds like you are asking about re-torqueing. After everything installed & torqued, all fluid levels full, CASE says to then start the engine, bring to operating temp. Rocker arms will need to come off, & starting with the #1 stud, numerated for torqueing, loosen 1/4 turn, then bring back up to torque. Then move to #2 and so on, following the torqueing pattern. What you will find is that if you simply put the torque wrench on & pull, without loosening 1st, is that most likely, the stud will not give. However, after loosening 1/4 turn 1st, you will find that you will come back the 1/4 turn, and then another 1/2 to 3/4 of a turn.
good luck.
good luck.
