Henrik Jansson
New problems
The last sleeve I pulled out has pores. All the others looked really good, and so did this one, except for a small part of it that has got alot of small pores. I stuck a needle in the deepest pore for about 2 mm. And the thickness of the sleeve material is 6 mm. Shall I get a new one? If I rotate in a bit, will it stop became deeper pores on this place?
This cylinder also had small cracks in the piston. Som maybe this cavitation is because of that. And I guess the problem is a earlier bad injector.
