930 hydraulic problem
Fellas,
I have a 1962 comfort King 930, its got a loader on it. I bought it here a while back and just got to start to use it picking up bales, the lifting cylinders works fine if you rev up the engine a bit, but the tilt cylinders have no power at all trying to tilt a bale back, I manually operated the lever from behind to see if its out of adjustment, and heard a noise from the pump area. Sounds like air or oil leaking by something. Doesn't do it on the inside valve. And has plenty of fluid in it. Thanks!
Is the float valve still on the pump? Usually on the left side hydraulic hose. Depending on which direction you are moving the lever, it may be bypassing oil in the float position. Maybe switch the hoses around on that circuit and try it.
I don't know if it is still on there I probably wouldn't recognize it. Its the right side giving me the most issues. Thanks
