burkhart01
Fellas,
I have a 1962 comfort King 930, its got a loader on it. I bought it here a while back and just got to start to use it picking up bales, the lifting cylinders works fine if you rev up the engine a bit, but the tilt cylinders have no power at all trying to tilt a bale back, I manually operated the lever from behind to see if its out of adjustment, and heard a noise from the pump area. Sounds like air or oil leaking by something. Doesn't do it on the inside valve. And has plenty of fluid in it. Thanks!
