Rod, finally starting to split the newer of my 1370, which as you might recall both are doing (or not doing) the same things. Got some questions.
Quick recap - both start and run great, all hydraulics work in both tractors, but no surge when inching pedal depressed and can shift any range or power shift with or without clutch depressed and no sound or action. We talked before and narrowed it to the front PTO shaft breaking after the hyd pump drives but before power shift, or sun gear at input of power shift.
Got an original manual and did some research. Going to work on the '75 first, save the '74 for next. Thought it'd be telling to fire up the '75 and see if the PTO spun. It does spin.
First question, correct me if I'm wrong, but if the PTO spins, it must be the sun gear broken since the main shaft which is driven by the front PTO shaft has to be turning also? Of course we'll find out here shortly but thought that might make sense.
Next question, how do you support the rear of the cab when splitting the transmission from the torque tube? Since I have to fix the fuel sending unit, was thinking of removing the fuel tank and chaining the rear of the cab floor board where the tank straps fasten, and supporting overhead from a substantial hoist we have (old Minnneapolis Moline Uni-Harvestor hoist). Take the vertical bolts out of the rear mounts, lift just enough with hoist to see pressure taken off the rear mounts. Any better ideas for supporting the cab when doing this?
Another question, you mentioned you may have all the gaskets I need for this splitting/repair job. If you still have them, let me know what you want for them. My email is [email protected].
Last question, if you dont have splitting stands with casters is there a better way to roll the transmission out from under the tractor than with some heavy duty floor jacks?
I haven't tried checking if the PTO spins on the '74, robbed turbo off it last year and haven't put it back together to fire it up. Will work on it later this summer. Could be front PTO shaft or sun gear, don't know yet.
What luck I have to own two 1370 with basically the same problem!
Thanks Rod and all for the help!
