Still Here Guys
Agri King
Nothing new here, my plate is full with spring coming up real
quick. Next month is Febuary right? We have a house remodel
project going on. Not by me!!! Been following Toms & Jim's
Case Facebook pages. Interesting, if you guys are on
Facebook.
Hi Eric, 4 lights on the rear fender, first time I seen that done. I always hide the JD oil buckets before I take a pic, LOL. Rod.
It can be a problem, wheel position sensor is most common. It's not the end of the world. I'd drive it around & see how the steering works in all 3 positions.
WOW you guys always amaze me at how you can work on tractors and still maintain a clean shop.
Agriking if you get a chance can you PLEASE show/share a picture of your dolly/stand that your using to hold up the rear of that 1570.
I don’t think I have ever seen a dolly like that. Does it have jacks at both ends to raise or lower the tractor?
When I split my 1370 I had to use boards to block up the rear end.
A stand/dolly like that would have made my life a heck of a lot easier and maybe a little safer
I've owned 3 "Crab Steers" w/ the electronic steering over the years. Anytime I had a problem, which was rare, always turned out to be a corroded connection.
Eric, Good to hear from you.There should be some good 1570 parts over at Salem salvage in sd.My neighbors place got hit by a tornado last june. His 1570's damage was to the cab[all the windows broke out and cab was leaning to the left]hood also leaning and sand blasted,front shroud missing,exhaust manifold broke and top of radiator broke off.Other then that the ef4 moved it about 9ft.A new holland combine next to it rolled several times but came to rest on what was left of its wheels.I tried buying the 15 but Salem put a bid in on all the equipment and insurance company went that route.Thanks for checking in over here. always interesting seeing what your up to.
It sure would be nice to see a picture of that dolly/stand you have the 1570 held up with. Is it home made? You have a very clean shop. It makes me think of an operating romm, but then it is.
