Blade Needed for Eagle Snow Removal
Any tree point hitch back blade will wyrk on the eagle hitch. Unless you insist on a case brand. Then it might be difficult to find one.
I happen to have a Farm King blade on my DC. It requires you use the "over the PTO top link mount. If you use the eyes on top of the rear end it will not lift very high. You will also need a short top link. The "Over PTO" mounts are rare mine is home built. If you are using the eagle hitch on a VAC it is an easier hook up but you need the top link to fit your VAC I used the same blade on my VAC 2 years ago while my DC3 was getting a new clutch and some rear end work.
