VC rear axle bearings
Dalex
I hear a growling noise from my left rear
wheel/axle. Will the axle and bearing pull out by just taking
off the 4 bolts on the retainer , or do i need to
pull the axle housing to get the brake drum off the
axle first ?
You should be able to pull the rear axle out without removing the axle housing. Just make sure you lock the brake on the side you are removing as to not allow the brake disc to drop. If brake disc moves out of position after axle is removed, you will need to remove axle housing to get it to spline the axle.
I think I have Band brakes ...I can look into the adjuster / actuator bracket and see the drum . I'll contact you off the board . Thanks !
