combine engine
in a earlier post I mentioned I had either a 188 gas or the 201. I don't know which only that it is out of a combine with only serial no. 2124971 on the tag. will gasket for tappet cover and oil pan be same for both engines? I am told on this site that the 630 used the 188 gas, need to order gaskets so I can try and run the engine. thank-you.
