Anonymous-0
I am new to the tractor world and i have a few questions about my older case 530ck with a shuttle shift (2 levers on either side of battery, and believe it is a case-o-matic from what i read on other post that if you can stop it with out clutch and it doesn"t stall, i think it has a torque converter?) now tractor was running/moving forward and backwards fine on flat ground but when i started up hill it didn"t go but back on flat ground it was fine (was i in wrong gear? hi/low lever not in right position?) and now it doesn"t move at all, cant get in gear it grinds, i found what i believe is the torque converter dip stick? and it doesn"t show any oil when hot? im assuming this is my issue? my question is what kind of oil dose torque converter take and what are the other oils diesel eng, diff, hydraulic? I am an auto mechanic so i have access to gear oil and atf?, also would like a little over view on how to operate tractor, where should levers be on either side of battery? there is 4 gear selections on center gear shifter and a selection marked "S" what is this for? thanks Scott
