411 Case Tractor Image Needed
Can anyone provide me with a high resolution image of a Case 411? Something from a piece of sales literature would be the best. I need this image to be suitable for our show poster. We are featuring Case this year, at the Almelund Threshing Show, and are giving away a Case Triple range 411. I need an image for advertising our tractor raffle on the show poster. Can anybody help?
There is no such thing as a 411 tripple range tractor. The Racine built 411s also known as the "big 400s" had a single lever dual range tranny, 8forward-2 rev.
The Rock Island built 411Bs "small framed tractors" were COM trannies with 8 forward, 2reverse with the converter drive and direct lockup, offering variable speed in each gear related to the amount of load.
Loren
Bruce, these are from the correct time periods that Triple Range was available, I can do a high res scan and e-mail to you if one of these might work, I have some Very nice 530 lit shots but the 430 is hiding in the nicer later lit
cnt
Bro, your pics are after 411 period of manufacturing. Yes Case did offer 430 -630 tractors, with tripple range but none of them were sn# as 411s. Serial# were 440-441, 431. None of the 430's had COM but had straight 4spd and optional triple range. 530 and 630's had the same nomuiclature describing options of tripple range , or 8spd COM., plus a straight 4spd tranny.
The last of the 430/470s had a simple 8spd. But there were varients from the construction side, such as shuttle trannys.
Loren
You really need to post pic with proper sn# The production of Case 430's /441s spanned a lot of years with many changes such as early 60's Eagle Hitch tractors to late model Draft-0-matic tractors into the early 70s.
Loren
The Almelund Threshing show is 40 miles NE of St. Paul, MN. Raffle tickets will be available in Mid April. The show takes place August 7-9, 2015
ok will send the scan I have if you are going to make a poster size pic I will rescan and resend let me know if you need to better one
cnt
