is this a top link for a 300 case?
jth88
im looking at this top link is it for a 300 case and what is the going price for a top link. thanks jt
That is what I use on my 311b, but the original was the same length of rod on each end or shorter overall. Start it off at $40.
It looks like a 300 but that type top link was used on several number series tractors and the size of the front eye G10473 can vary. I don't really remember what size that eye is on 300 but I think it was around 1". The pin G10472 that passes through the front eye G10473 must match the bore in the brackets G1051.
There were 2 different lengths of the rear adjusting eye VT3006 being the common size and VT3162 is an extra long eye, appears to be the end you have.
In good shape anywhere from $50 to $100 in my area.
Joe
Not for sale. I don't use the Eagle hitch at all on my 310 but all the parts are on the shelf for the next owner after I croak.
Joe
The ones I have both have VT600 marked on the center castings. And as far as the thread part on the shanks they both appear to be different and so do the ends as well as the length of the shanks themselves. I know the one with the round end is for a VAC which is the older brother to the 300. The pictures show the one I have for the VAC at the bottom and the other one I am not sure what its for but the Veterans on this site will let Us know. As far as the piece that is broken on the casting of the one Your looking at? As far as function it would work just fine. If You want a restoration piece keep looking But the one You have pictured looks pretty d--n nice to Me. And its nothing a side grinder and ten minutes couldn't handle. As far as price around My area it would sell for $75-$125
