411 gets split
chuck machinist
Went to Illinois and met up with Pastor John and cousin Scott Last week. The split went well We found the clutch was to the point of toast. The flywheel need dressed up .010 to .015 cleaned it up. Just a few fractures remained. Nothing we could not live with. A clutch was expedited from Indiana in 1 1/2 days. Rear crank seal replaced as well as the input shaft seal.bearing and oring in the flywheel. Constant ribbing from Scott and John carried through for 3 days. A small price to pay for all their free labor. Pastor John made good on cleaning out the 90 weight from the rear end. A lite spritzing of enviro solve ,and wiping down the bull gears, and pinion .The clutch shaft bearing and seal was also replaced, and the baffle plate modification was installed. A fresh gasket was made for the rear top trans cover, and Pastor John replicated a new belt pulley gasket under careful tutelage. The Marvel Shieb. carb was rebuilt and set by Scott. I made sure that Barley Pops were kept at a precise temperature,and proper seal/ bearing installation. Ron Shank stopped by to check on the seal and bearing install. Thanks to Bill Brackemeyer for lining up a local Machine shop for flywheel cleanup. Thanks to Eli Gansen for his tech support. To John and Chris Saeli ,many thanks for bearings and seals. The test ride @+10 degrees went well, We were able to accomplish 80% of the project, but are they ever really finished? Thanks for listening. Chuck Machinist
Glad you guys are having a great time. This pic is my well worn and tattered T shirt. that I wear often.
Enjoy, Loren
Chuck,
Glad the split went well. It's not too bad of a job to do. Been there done that on the cold tractor rides.
Eli
Chuck - Glad to hear that you accomplished what you set out to do. Was wondering if the Pastor was going to help. If you get back to Iowa, other than the WHO tractor ride, let me know and may be we can get together.
Yikes!! That ring and pinion look worse than the ones I took out of my 400. I replaced mine cause I didn't like it. Just a friendly suggestion, your SMV sign is upside down. One point should be up and two should be down.
Eli
What is the purpose of the baffle plate modification? Can you elaborate? Did J.I. Case issue a factory tech bulletin back in the day? Or is this a home-brew improvement to help fix tranny noise and extend bearing life?
Thanks inquiring minds want to know....
The service bulletin was implemented when farmers used road gear and the 90wt gear oil belched from the vent pipe on the rear transmission cover. Hope that explains it.
