brake problem
mickeylee
New User
I have a 1983 case 2290. (brake problem) I have to pump brakes 3,4 or 5 times and they work perfect after that, locks (duels) on either side with lite pressure, next time I use them it is the same thing again, have to pump them again. Both left & right sides are the same way. What is my problem??
Any help would be greatly appreciated.
Thanks Mickey in N. Carolina
have you bled them properly? any time you change trans filters and or oil this needs to be done, look in your ops manual for the correct procedure
cnt
