kip78
i need to put in a couple remotes on my 411B for a haybine. can I tap in to the eagle hitch or case o matic somewhere? I have no clue how to get it going, and I really don't want to cut 40 acres of hay with my ford 501 again.
I have a 530 with only hydraulic on 3pt lift and needed a remote so replaced the pipe from control valve to cylinder with a hose to a splitter valve mounted on the mudguard with a hose from there to the lift cylinder and screwed a breakawwy coupling into the other pressure port. It could only be single acting and can only be used one at a time but a flick of the finger was a quick and easy switch. It worked well for many years.
