Need help on PTO install on 530 COM
I have a 530CK loader. Diesel, three point draft control,8 speed, forward/reverse lever with no PTO. It has the PTO blank cover. Can I install an independent PTO unit I have and if so what needs to be done to install it? Thanks. Dick, in OR.
Untitled URL Link
Wrong,,, a shuttle 530CK can have a pto I have one here, if it is a standard trans with shuttle it can only have a non-live pto, a com with shuttle unit can have a independent pto but you have to change the through shafts, it is not a easy job but it can be done
yes, it will have to be split at least once to get to what you need to change, you also need a donor tractor to pull the parts from so you get every thing right, it is not a real easy swap to install pto on shuttle tractors, I would suggest a parts book to make sure all you will need before starting, I do not seem to have a 530CK parts book here sorry, you may be able to find it on line @ CASE Construction
