I don't know where to go. My 530ck gas starts and run's the best but when under a pull it don't seem to have any power and will pop back through the carburetor. I mean pop hard enough that it will blow oil out of the air cleaner. New points, condenser valves set right no miss when running. No uneven cranking when starting like a bad valve. It just starts pulling down pretty quick and blows back through the intake three or four times and dies. It is not like it is lean on fuel. This is the one that when I bought it would not rev up and the cam gear came loose. I fixed that. Don't know what to try next.
