I have a case 2294 that won't move but the steering and lift arms work I was using it and it worked fine I went back to it a week later and it wouldn't move. I've changed the hydraulic filters and now it inches forward a foot and stops again. It whining and hydraulic line is vibrating from pump behind drivers side rear tire any ideas??
can you hear clicking from the circuit board under the shifter console?
check to make sure your inching pedal switches are clicking and not stuck as well
I haven't checked but trust me I will. Does tractor have to be running or will they click by turning key to the run position? If I don't hear clicking what would be my next step?
if you cannot hear clicking from under the range console when you are pressing or releasing the inching pedal, I would suspect that the circuit card is fried or has a bad wire. they go bad, recently mine fried from faulty solenoid wiring. First check fuse panel for blown fuse. Two of solenoids on control valve should be activated in any range and are magnetized. With tractor running in neutral see if a small flat washer (3/8 or 1/2) will stick to two the four solenoids
I took shift lever console apart and found circuit card it's not clicking and the purple wire in the number one slot is fried. I checked the solenoids on the passenger side of tranny and no power I used a test light and I tried the washer trick but no luck and all my fuses are good. If its the circuit board where can I get another one??
case dealer..p/n 47689399 runs bout $200. You need to make sure that your selonieds are not shorted or you may burn up a new card! someone on here has posted what the selonied resistance should be when checked with an ohmmeter. hopefully they will chime in or re post a new thread asking that question
Thanks for the help karl my name is scott I spent the afternoon tracking down bad wires and fixing I'm gonna try to solder that one bad spot it's worth a shot also I noticed the power shift range switch is cracked up. It's been a great tractor and plenty of pulling power only has 4450 hours this is the 1st major problem I've had
Hey scott someone has a new circuit board on ebay for 75$ new.be cheap enough to try just type in the part number,if it is still there.
I'm gonna need alittle more input I soldered the #1 wire back to the circuit board but I have no fire going to the tranny fuse I checked the relays behind the console the 3 on the rt click but the 2 on the left don't click. My main question is where does the tranny fuse get its fire? The wire to the tranny fuse goes to a relay in console and it clicks but don't understand why fuse don't have fire. I have a new circuit board ordered
