Antifreeze on the floor - DC Case
agonair
Well, today I went out to the shed where I am storing my DC for the winter. I walked in and all of the coolant has leaked out onto the floor.
No leaks when I parked it and the coolant was protected to -20. I had just washed the tractor and parked it.
I got a light and cannot really see where it is coming from. Not from the engine. It appears it is more to the left underside of the radiator.
Now what?
I have had a couple leaks from my DC radiator. it's original and can 'rot' thru almost anytime. I used one of the 'metal putty's, available these days.. after carefully cleaning the leaking area. A wire brush can make matters worse !
agonair,Check your hose clamps for tightness with the engine cold.Cold weather causes the hoses to shrink and antifreeze will leak at hose connections when cold.But will stop leaking when the engine is warmed up.
