idiots lights
gooddirt
New User
: there are 3 idiot lights on the dash of the case 1030 tractor they are
faded and i cant read them. do you know what they are for? from left to right.
they are for oil pressure, fuel pressure, and charging
I think the left is GEN for charging thru middle is FLTR for fuel pressure and the right is OIL for oil pressure.
gramps
On our Case 1030 when I get the filter light, I
start by changing the first filter in the system.
About three times in the last 15 years the filter
light has come on. Every time changing the first
filter cured the problem.
Hope this helps.
Many Thanks
Just change the first and second stage. Third stage seldom needs changed. Only third stage filter I have changed is one that had rusted and leaked.
Gene
If you change the first filter and the light doesn't go out, unhook the wire from the sender and see if that makes it go out. I had a 930 that after changing all 3 filters, the light stayed on. Come to find out, the wire had rubbed through in one spot and was grounding out.
