This doesn't happen too often!!
John Saeli
Nearly fell off my chair when I discovered this, but a Genuine CASE, Made in the USA, Air Pre-Cleaner Assembly, Lid, Bowl & Base is about 1/3 the price of the same thing in the aftermarket. Go figure.
I used to see it a Lot with CASE,,, with CNH not so much anymore,, I used to be able to (and still do at times) buy bearing from CASE at a far less price than a bearing house, like stated buy big #'s get a big discount,,, sadly they do not always pass on the savings anymore
cnt
Tom: You are correct. Years ago CASE had the best prices on bearings, seals & engine kits. Not now!! I don't even dare buy bearings from CASE anymore because some are China. Never used to be that way.
you are correct on that John, I bought a dozen bearings for my "ED" drill disc last summer, cnh was $4.00 each cheaper than my local bearing house,, sad times
cnt
About 25 years ago I rebuilt a 930 and 2470 over the course of three years. Complete kits from Case were about a 1/3 cheaper from Case than from the local parts house. For other bearings I use a independent supply house in Grand Junction,Co that has a huge inventory, has stuff you would not expect them to have.
