1952 Case sc charging issue
Bhunt
!952 Case SC Can anyone help with a drawing for a motor craft 1g alternator and what I believe should be but not sure a B circuit voltage regulator. I posted photos from a previous post you had , I have the same alternator but have not bought the regulator yet, should it be A circuit or B circuit?. Note: the alternator will charge full field. Long story short I removed the magneto and installed a Delco 1111411 distributor now I need a way to charge the battery.
I would be thankful for any Help!
If I was doing it I would go from the switch to the S terminal on regulator. A on the regulator is hot all the time. F on the regulator runs to the f or field on the alternator. I wouldn't use I on the regulator or the s or stator terminal on the alternator. Run the battery wire of the alternator to your amp gauge. Make sure regulator is grounded good and it should work. hth, jstpa
Thanks for the reply jstpa, I will give that a shot. I'm also looking at changing the gauges have you or anyone had any experience with the case gauges made in India they appear to be the same as the ones they say are made in America but a third the cost. I'm looking at the sc tractor ebay site.
