Case 300 series?
Kuebeck89
Looking at buying this tractor, I think it's a Case 300, can I get any help on it with Info? Don't have a serial number I thought it might be on the steering column, any other suggestions?...
Also what's it worth?
(reply to post at 17:52:31 01/22/15)
I would probably replace anything that was damaged, want to do a complete refurbish on it. How do I know what model this one is? It's my first case I'm normally a ferguson guy as I have 5 of them.
Im new to tractors and bought a roundnose like yours a few weeks ago. One of these other experts can tell you exactly what model it is, but it sure looks like my 56 model 311. My serial number plate was straight down below the steering wheel, down low. Awkward to find.
Tractor is a 1956 or 1957 model 311 in the 300 series tractors.
Model/Serial nr tag can be either of the locations in the pic. You should be able to see the fastener holes if the tag is missing.
It has a 148 cid engine, Nebr test lab rated 29 hp on the ground, 31 hp belt.
Hard to tell in this pic but looks like it has the hand clutch option. Probably has triple range and Eagle hitch but need right side and rear pic to be sure.
Joe
