MEL question
Jerry He
Have you ever put a 504 engine together with no head gaskets using only fire ringed sleeves? This engine will be running around 70 lbs of boost.
No, but know those who have, The common setup is to remove the stock firering and install a specially made one and use the stock gasket as well. I could get the info on the supplier for you or get you connected up with someone who knows more about it.
