Dave in
I am working on a vc case front bolster I need to replace the bushings part number VT-2220 witch I think I can match up by size . what my problem is the shaft part number VT-2221 is also worn my question is this shaft the same in a vac tractor ?
Only the chicken roost VAC is the same. My VC and chicken roost VAC are both sloppy but only on top so I plan to take the bottom spindle shaft off and turn down the vertical spindle and make an oversize top bushing as the bottom is pretty good still.
I haven't looked at the bottom that close yet but I know I have .045 worn of the top I will look at that I also have a part tractor VAC with the chicken roost arm hat might be in better shape
