Case 300 Progress
connor9988
Location
Central Iowa
The clutch wasn't acting like it should when I pressed down on it so we decided to split the tractor. Here is what we found.
Those damn mice will find a way in almost anything. A few years ago I split a 300 that had been sitting in a grove for a few years. It was so full of mouse crap and litter that it caused a major rusting problem on everything in there. I had to use a portapower cylinder to get the tractor apart tearing the pressure plate. The shaft was rusted tight in it. Rod.
We had the same problem. Had to you a block and bottle jack to get the motor away from the bell housing. Made 2 big pops and came free.
