tluchterhandt
I've got a Case 830 CK that is having trouble with the top left hydraulic remote. The tractor has 2 remotes on top and 2 on the bottom. The inner lever controls the 2 remotes on the bottom. Moving the lever rearward pressurized the lower right coupling, moving the inner lever forward pressurizes the lower left.
The lower right operates as it should, but the lower left if I move the lever as it should be moved, loads up that side and seems to over pressurize and the cylinder won't move. But if I move it very slowly it will move the cylinder at a very slow rate. Pick up the pace and it loads up again. I have to wait a few seconds after it loads up for it to operate from either right or left. Any suggestions on what to look into?
