1930 C Case seals
BT in NE
I am working on a C tractor and am wondering if someone can help me. I want to replace the belt pulley seal, and the transmission brake seal with modern style lip seals and do away with the old felt ones. Has anyone done this and would share the part numbers? Or a website that will match the dimensions? The old ones I have are in good enough shape, but I hate the thought of going through this and having leaks if I can help it. Any help is appreciated. BT
should be very little oil in the clutch ares if proper plug is in rear of crank.. Flywheel puts it back in crankcase usually does not need much of a seal
