vac/vah cultivators
Some of the linkage parts are different. Also, the VAH standards are longer. This means that although most parts will fit, you will need to extend the standards and find the linkage parts for the rear gang if they are missing.
So if the VAH just has the frames, the standards, clamps, etc from a VAC cultivator won't work? How much difference is there in length?
Anybody have a picture of the rear tooling on a non-eagle hitch tractor?
Mike
(quoted from post at 19:38:49 01/12/15) So if the VAH just has the frames, the standards, clamps, etc from a VAC cultivator won't work? How much difference is there in length?
Mike
Google is probably your best bet for a picture. A lot of the parts are not common to other cultivators and you're stuck finding VAH parts. I believe the shanks are larger diameter also.
