engine oil pressure/pump help?
jsfarmall
A real good friend of mine has a VAC case that he overhauled the motor on and does not have good oil pressure. He is looking for a pump and best price he can find is 400 dollars. Can anyone help?
Has he checked to see if the pressure relief valve is working? Could be that it is hanging open. or the spring may have broke.
Make sure he didn't loose the metal hollow stem that slides up inside the oil filter. You will have very little oil pressure without it.
Honestly I don't know if he primed or packed it. If I was guessing probably not. I remember him mentioning something about a hollow tube so he probably didn't forget it. Everything he found for a new pump is around 400 bucks.
