VAC-14 Belt Pulley
Glenn F.
Way ahead of myself here as I haven't started working on my little tractor yet, but are all VAC belt pulley mechanisms the same? At this point my tractor just has a cover plate. I need to start gathering parts.
Thank you,
Glenn F.
(quoted from post at 08:43:44 01/12/15) Way ahead of myself here as I haven't started working on my little tractor yet, but are all VAC belt pulley mechanisms the same? At this point my tractor just has a cover plate. I need to start gathering parts.
Thank you,
Glenn F.
All of the drive assemblies are the same as long as you get the right one without a hydraulic pump on it. The VC used the same drive as well but those had a cast iron pulley.
(quoted from post at 11:14:29 01/12/15) Why does the one with a hydraulic pump not work ?
Thanks
functionally it will work but it's not correct nor can you shut it off like the correct one.
