case 530 disk brakes?
R&W
can u replace the brake drums on a case 541 with double-disk brakes from a farmall super series or something?
(quoted from post at 18:01:31 01/11/15) can u replace the brake drums on a case 541 with double-disk brakes from a farmall super series or something?
anything is possible with a torch and a welder but why? That's like putting Buick brakes on a Toyota, tons of work for nothing!
i was asking if they would fit with little modification. i don't like the drum brakes. and disk brakes are cheaper.
The drum-disc combination you have is very efficient. Re-line kits are very economical. Earlier 530's did have double disc brakes, & from what I can tell, the splines are the same. Therefore, a double disc brake unit from an earlier series CASE should work. Those discs are $43.00ea. USA.
(quoted from post at 09:32:19 01/12/15) The drum-disc combination you have is very efficient. Re-line kits are very economical. Earlier 530's did have double disc brakes, & from what I can tell, the splines are the same. Therefore, a double disc brake unit from an earlier series CASE should work. Those discs are $43.00ea. USA.
my 530 has the disk/drum setup on it and it'll stop a loaded wagon pretty quick. You had asked about putting brakes from an IH super on and that is a completely different spline size and tooth count.
