hydrostatic steering stuck on Pops 430
01gentdc
uh-ohh,,never had this happen before ,Have Any of You ? , and can you give me some ideas ?///,musta cut the wheel TOO hard to left ,and now it is stuck that way ,,.it is hydrostatic with the 2 cylindars under oilpan , my guess is that the missing axle clip has a lot to do with it ,,. probably oversteered , mite have lost the retainer clip in the piston ,will try removing hydro lines , to determine if the problem is in the cylindars or steering wheel motor..
Take a pry bar to the wheels and make sure that the steering sector in the axle hasn't overcentered and and that one of the cylinders has lost it's folcrom point to push the sector the other way.
Loren
ok loren,, will give it a try ,, I suppose one cylinder has bottomed out to where it cannot accept fluid ,,
