Working on an 800 wheatland propane. Thought I had it where it needed to be until I found a valve (vapor) that leaks. Have taken the regulator and carb apart and they LOOK ok but this is my first propane adventure and I really know nothing about them. It will fire if I squirt starting fluid into the carb but it's like the throttle has no effect. I has a Jimco regulator and carb. I'm very likely omitting important information but this is a start. It won't be running on LP until I get a couple of new valves for the tank. Thought I'd better get some advise from you experts and save me some headaches.
