connor9988
- Location
- Central Iowa
Well I got the gauge cluster apart and it doesnt look good. ACG Ill be emailing you shortly. Also I cleaned up the exterior of the starter and will be taking it in to get looked at. Once the burned parts were removed from the distributor it looked pretty good so that is a plus.
Is the rear toolbox factory? its mounting bracket looks farmer made.
Also, How does one get in around the dash to remove the bolts that hold the hood & grill on?
And lastly a picture of one Case being used to help the other.
