Quick update in 440 console range lever.
Adirondack case guy
Eldo Case hit the nail on the head as to why I didn't like the extended lever on the range lever. Not so much of a posability of forcing a shift, (I know better), but the posability of the extended lever forcing the rail out of the detented position in high range and rideing the fork/collar.
My console designed lever overcenters in both ranges, eliminating that problem.
The tractor range lever and my console shift lever have counter revolving archs, so a slip joint was required to allow smooth rotation. No problem, just needed to fab a pivoting tubular trunion that a rod (the console lever) could slid in. I need to thread the end of the lever and buy another of those $5.50 knobs for the end.
It took longer to bend the frame for the console cover, than to build the linkage. HeHe.
Loren
Eldo, the bolts slide through the tin work and thread into 5/16" cage nuts in the strut that holds the whole dash assy. Not an issue.
Loren
