Adirondack case guy
Pics arn't what you might have expected, but I ame at the turning point from design and fabrication to detail finish work and paint. All 4 panels front, rear, right sidefull panel, and left side with door, all are removable as I hoped. Had to remove the rear wheels to drill and tap holes for the smaller panels to enclose the rear axle housing to the cab. (details-details)
Did some more fabing on my hyd. control counsole and added a a temperary extension to my dual rang lever, to see if I liked it. I think I will go to plan B, a lever like on a 7-1030CK on the side console that I will build, that will bolt to the black support bracket holding the hyd levers. O well, just another days work, HeHe.
At 4:00 I sat down in my pondering chair with a barly pop, and have mu MOD 3pt Eagle Hitch all built in my mind. Just need to find a couple of hyd cylinder at Surplus center that I can link into a fabed rockshaft mounted in the unpainted brackets in the pic. and then jusr hook the hoses to one remote.
Loren
Loren
