Paul Shuler
Hi, a few months ago my wife inherited a Case 1690 tractor from her father. I have been using it around the place. It is way newer than my next newest tractor. A 1953 Farmall super C. When I was moving some gravel with the loader. I noticed the steering was getting very stiff. then it would be fine then get very hard again. I checked the power steering pump and it was very low on fluid. Which leads to my question. I have a manual with it and it says to fill the pump with 1 1/2 quarts of Case TFD fluid. I have been on google and everything else and cannot find what TFD fluid is. Is is just hydraulic fluid like HY Tran or is it more of a power steering fluid like you might find in a truck or car? Sorry I am so dumb but this is my first Case and my first tractor with power anything. I will be watching my crankcase level cause I am assuming a bad seal in the pump might dump the fluid into the engine. Am I correct to assume that?
