530 utility pto
Zach81
I have an early 530 utility with a homemade PTO delete cover. Found a factory cover to put back on, but when I did I saw what appeared to be PTO drive in the trans case. I thought it was like a cup plug for where PTO drive would go, but to my surprise it spins when the clutch is out and the shuttle is in gear. Could this be a broken PTO drive??? If so, I'm assuming a split to replace?? Thanks for any advice.
