What did I get for my VAC-14
kevsdodge
I purchased a top link listed to have came off a VAC-14. Not having one to start with I saw it was marked with VT-600 had a mounting pin and the spacer so I thought I had found what I needed. Not so fast the mounting pin I found is way to big for the bracket on the VAC. The diameter is 1 1/8 inches. the center to center as shown in the photo is 19 inches. the question is what did I purchase and is there a market for it?
The turnbuckle VT600 is the same for VAC & 300.
The bracket end (LH) eye of your top link is 300 series and some others in the nr series tractors.
The eye will accept a 1-1/8 pin, however, the correct mounting pin to fit the 300 series mounting brackets is 15/16" to 1". The pin may be larger for brackets on other nr series tractors?
I will take some pics of my VAC and 300 series top links and post tonight or tomorrow.
Joe
That is for a number series tractor, but you can make a bushing to fit the clevis pin on your VAC and most people will never know the diff.
Loren
I am not very familiar with the 14. If your bracket is like the parts pic, you need the same top link as the other VAC's.
Joe
It may not be correct for the police, but it will work and it appears to be a good since is about as short as it will go. Many of them have damage on the threads.
Nick I spent way too much. The seller as agreed to take a return and refund the purchase price of $258.00. Would you want this or wait to see if it goes back on Ebay
(quoted from post at 14:10:43 12/04/14) Nick I spent way too much. The seller as agreed to take a return and refund the purchase price of $258.00. Would you want this or wait to see if it goes back on Ebay
VA top links usually bring under $100 shipped.
