Working on E21 Plow
connor9988
Location
Central Iowa
Working at removing the old EH pins on the plow so that I can put in standard 3 point lower pins. This will let me use it with the VAC or any other 3 point tractor. The EH pins are standard thread so ill have to look around for standard thread 3 point pins.
Don L. I've been meaning to call you about that VA seat back. I just need to get some free time to come up too.
Nice setup you have there ! I have a Stockton Hitch, and am trying to make a set of Eagle Hitch arms work on the back. There's a 2-12" in Missouri for sale, I'd like to put behind my VAC if I can make the lifting arms switch work. How deep and what gear do you use with this plow?
Mike
That plow in MO is a model E and though You cant see the bottoms by the looks of the pins and top link hole it doesn't look like it has been used much.
Here's my E 24 I restored 2 years ago. Only plowed Some headlands with it since but worked good. I switched It to Eagle bottoms.
[/img]
