1370 power shift transmission question
Brokengun
There is a 1370 on Ebay for sale and the owner says its got the following problem.
[Power shift trans that shifts real nice, but the 4 speed gear portion of trans jumps out of 2nd and 3rd gears under a load at times]
Question is what would it take to fix this tractor?
worse case scenario a split like a powershift only just a bit deeper as the powershift support housing must be removed to service the 4 speed if new collars and gears are required.
If I were doing the job I would reseal the powershift and replace the c2-c3 carrier bolts in the deal while it's on the floor.
You could get lucky and just need shift fork parts and detent springs, these are in the shift cover so could be inspected without a serious teardown.
There could be bearing issues as well and that could really get in depth if the pinion shaft needs removed.
