Big 400 narrow front to a 730.
I do not think so. The 400 tub is about an inch shorter and the fan will be in the radiator. You can make some spacers to put between the tub and the engine flange and it will work fine. if you look at some of the early 800s you can see in the casting where they extended the the tub.
(quoted from post at 20:28:36 11/23/14) I do not think so. The 400 tub is about an inch shorter and the fan will be in the radiator. You can make some spacers to put between the tub and the engine flange and it will work fine. if you look at some of the early 800s you can see in the casting where they extended the the tub.
Never had this problem before and my 400 has an 830 tub on it!
