Was using the tractor yesterday to pull a load of corn to the auger & then pull the auger away from the bin & park it. I stopped & then went to move the auger ahead a little more & the tractor wouldn't move or go into any gear. No engine noise when pushing in the clutch, only a clicking noise. Transmission pressure was good & wasn't locked in any gear. Had to pull it into the shed. Brakes, steering & hydraulics work. Couldn't see anything externally wrong but the clicking noise seemed to be coming from under the ps cover, Power shift & range selector levers move as they should. Is this going to be bad news. Need expert advice.
Thanks,
Dennis
Thanks,
Dennis
