fixerupper
Here's a pic of my beloved little SC taken at our local threshing show a few weeks before the show. Case was featured the year this was taken and I was asked to bring the SC to pull a binder for pictures when the wheat was shocked. I dropped it off and left figuring someone would hook it up to a binder and go with it. Later when I came back to the show grounds to check up on things they were just hooking it up to the binder and I was elected to run it.
It's a 48 model that dad bought in 1970 to run an elevator elevating corn into the crib. It was not running and when it arrived it was rolled off the truck straight into my old shop. If I remember right the mag was a Fairbanks off an AC and not working so I got another mag from a salvage yard and soon it was running. Eventually I put a Delco distributor conversion on it and have never regretted it. It did not have hydraulics but it didn't take me long to add hydraulics from a donor tractor. The only serious engine work I've done is to replace the O rings on the sleeves. Today it is the most used yard tractor on the farm. It starts first time over, it still on 6 volts and with the hand clutch is so easy to just get on and go. On Monday it will be on a 10" truck auger loading trucks from a bin. Once again the hand clutch makes it so darned handy for that job. Once the auger job is done it goes back in the shed where it will be eagerly waiting for the next job. Jim
