Case Silage blower?
That is relic that should be saved and demonstrated at tractor show when CASE is featured. It is a combination chopper and blower with belt drive. Mature corn would be cut with a binder and loaded by hand onto wagons. At the silo, the wagon would be pulled along side and manually unloaded from the side using long handled square bent forks. The entire stalk would be slid onto the the conveyor where an elevator style chain carried the stalk bottom first into the chopper,with cut silage fed into the blower and into the silo. The farmer's silo could be built of wood and measure about 12x35 to help feed fewer than 20 milk cows, probably milked by hand
just stumbled across the exact same pix in a older ad that called the machine a straw chopper ,, ,, priced at 550,, regardless someone needs to save this from the seller who has no idea what they have ...
