1952 VAS RADIATOR CAP
amo
IS THE RADIATOR CAP FOR A VAS the same as for a VAC?
Is cap the same for the radiator as the gas tank? Thanks Amo
Yes, the VAS and VAC use the same radiator cap, and yes, the two caps will interchange (I just went out and checked). However, the gas cap is vented and looks different, and the radiator cap will not fit through the hole in the hood when you open it.
