Case wheel disc
1legonutt
I don't normally post here but I ran across this case wheel disc at a scrap yard it in pretty good shape. Just one gang is bad bearings pretty bad the bearing spools are three piece the center and two end washers. The end washers are shot dose anyone know if they are still avalable or a easy way to fix it.
Rob
They are no longer available. That is a model S disk. The model SA was identical but it had sealed bearings. From the first picture, I would say your axle is broken, not the bearing. It will likely be 1 and 1/8 square unless it is a really early one, which would have had 1" square axles.
I hope some one buys that little Case disc. It can be fixed. I have been using aftermarket parts from Agri-supply and shoup to fix my case disc's
