Tequila
Looking at this MXT to purchase. I found a metal ID tag on the
left side with model an this I D number,(J. G0300209) but no
Serial number.. I can't run down any info with that number.
Can anyone help me to locate the SN.. Would like to know the
year of Mfg. Thanks!
(quoted from post at 16:11:09 11/03/14) I guess I am a dumb Case guy, but what the heck is a 570MXT??
Loren
Loren,
The 570 series was the loader series equivalent of a M tractor/loader without a backhoe and most were equipped with a mod hitch (3 point ) with 1 hydraulic 3rd link and I believe rh lift link cylinder, there was a multisection valve mounted to the right of the operator to control the hitch. There were hookups to control a heavy duty blade angle and tiilt hydraulically.
We had several at sawmills to handle sawdust and mulch and put rooftop AC condenser units cause of plugging the front mounted ones.
The old equivalent would have been a 580 loader tractor, just a different model designation. HTH,
mEl
(reply to post at 06:59:26 11/03/14)
Teq,
Looking at your previous note, a common serial number sequence would have been a JJG number. Some later machines had the number on the side frame right ahead of the cab side window, years before that there was a serial number plate below the cab on the frame in behind the step into the cab. It should also be stamped into the top of the frame on the right hand side right behind the radiator shell. Raise the hood and clean that area , it is usually a good pronounced stamping with fairly large numbers.
Mel
